Author Topic: Urgent Help Required!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 3518 times)
Offline jharar
Re: Urgent Help Required!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #10 on: 17 February 2008, 16:23 »
It was the fuse mate!!!!!!!!!!!!
The fuse Ive changed was not blown at all but by just changing it all wen t back to normal.
Only the thing is my alarm fob is not working do I have to reprogramm it is there any other way of doin.
At the moment I am locking the car with  the key light starts flashing on the door card , But when I open the car with key alarm goes off , Quickly i have to put the key in the ignition barrel then it's fine.
Offline Rhyso
« Reply #11 on: 17 February 2008, 16:27 »
cool
have a search; there's a procedure to resync your remote with the car; you need a spare remote though
also - no need for the red highlight - makes it a little hard to read your posts  :wink:
Offline Rhyso
« Reply #12 on: 17 February 2008, 16:32 »
try the following
1. Place your first key into the ignition and turn to the second notch (do not start the car)
2. Now close the door and place your second key into the handle lock
3. Turn the key to the lock position and let it spring back to the central position.
4. Hold down the Lock button on your new remote, you may hear a bleep from the car
5. Now unlock the car using the key in the barrel and remove, then take your first key out of the ignition
6. Close the door
7. Your remote should now be coded
Offline richw911
« Reply #13 on: 17 February 2008, 16:38 »
try the following
6. Close the door
Sticky maybe mr rhyso?  :evil:
Offline Rhyso
« Last Edit: 17 February 2008, 16:43 by Rhyso »
Offline richw911
Offline jharar
« Reply #16 on: 17 February 2008, 19:06 »
Here I have got new problem, Ive got only one key.........
So what do I do here now go to dealers & buy new key fob  :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
 :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided: :undecided:
Offline richw911
« Reply #17 on: 17 February 2008, 19:19 »
 If you got to the dealers your be looking at £130 for a key fob  :sick:
 Then you will have to get it cut and coded  :cry:
Offline jharar
« Reply #18 on: 17 February 2008, 20:24 »
sO WHAT IS THE SOLUTION THEN ????????
DO I HAVE ANY LUCK OR??????????????????
Offline Rhyso
« Reply #19 on: 17 February 2008, 20:27 »
find someone local to you with VAG COM; they should be able to reset your key for a few beer tokens :afro:
not much else to suggest i'm afraid mate  :sad:
