Author Topic: First signs of a problem?  (Read 3567 times)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
Re: First signs of a problem?
« Reply #10 on: 16 February 2008, 21:35 »
There is some sort of K&N cone filter set on mine for some reason... do you think this could be helping the engine stall/cutout?
Offline Grim_Reaper
  • warningz...i haz powaz
« Reply #11 on: 16 February 2008, 21:47 »
its possable...if you have an origonal unit at hand then fit it with a new panel filter and see if it makes a difference
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 16 February 2008, 21:58 »
ecu temp sensor....
are you sure your not guessing now?? :p
actually, somone else said temp sensor on my thread too so it may well be
this controls the temp gauge and sends a signal to the ecu for more fuel... ive fitted several over the years and is a common fault... :smiley:
Offline max33
« Reply #13 on: 17 February 2008, 09:59 »
dipping clutch whilst going round a corner ?? that would be coasting pmsl try changing gear before you get there next time  :laugh:
Offline saul79
« Reply #14 on: 17 February 2008, 12:43 »
temp sensors on all vw 's are a common fault lol
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Mikester
  • Civic Type R
« Reply #15 on: 17 February 2008, 17:30 »
« Last Edit: 17 February 2008, 17:59 by boneybradley »
