Author Topic: MK3 golf gti 2.0 8v air filter  (Read 5547 times)
Offline kr1s77
Re: MK3 golf gti 2.0 8v air filter
« Reply #10 on: 17 February 2008, 05:23 »
what does drilling the air box achieve?  thinking about doing mine, i have run some ducting from the lower grill directly into the air box. so will i gain anything from drilling
ASV 1.9 TDI 110
Offline golf-gti-matt
« Reply #11 on: 17 February 2008, 08:54 »
It just enables more air to get into the engine, say at the moment the air filter has one cold air feed, if you dill lots of holes the, amount of air able to pass the filter is greatly increased.
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 17 February 2008, 13:38 »
drilling the air box only works if you drill the wing side (otherwise you get hot engine air that kills power)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« Reply #13 on: 17 February 2008, 14:20 »
As whoever put on the rubbish Kand N induction kit on my car is causing it to splutter and cut out, Im lookign for an original / replacement panel box?
(the actual filter housing black plastic box case thing)!
Anyone have one?
Its worth an ask as a lot of you may have replaced yours for cones and have the old ones lying around?
If not, where can I get one from?
Thanks
(mk3 16v... would this be the same box as the 8v?)
SuperSaiyan4
« Reply #14 on: 18 February 2008, 10:50 »
Well I will be installing the K&N induction kit on my car but not getting rid of the original box.
I also have brand new Iridium Tough plugs installed and that improved the car a bit.
Offline remapped
  • If you are going through Hell, keep going
« Reply #15 on: 18 February 2008, 11:41 »
i have a spare piper panel fillter if you want ?
£20 ???
OEM(ish) G3GTi 8v5dr
