Author Topic: Help! : Getting cable through bulkhead?  (Read 4651 times)
Offline neg
Re: Help! : Getting cable through bulkhead?
« Reply #10 on: 13 February 2008, 00:36 »
You say this gauge is electronic so doesnt have a boost pipe?  Sorry  :embarassed:  Where do you connect it to ?  I ask as I have a Forge DV and there was an option for a boost pipe feed if required.
You got a pic of the gauge?
Where abouts is switched live on these cars?
Offline john_o
« Reply #11 on: 13 February 2008, 12:54 »
nice one!
where is the grommet inside? i havent looked so not seen that, you didnt have to take anything out?
under the glovebox is a foam panel , 2 fixings and it easily removes , as soon as you get your head under its easy to see where the big cable feeds into bulkhead
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline john_o
« Reply #12 on: 13 February 2008, 12:59 »
The DEFI range have a short 'boost pipe' run from feed to a sensor (which you keep in engine bay) , then an electrical connection from the sensor to guage.
DEFI BLUE RACER 52 mm can be seen in my earlier thread
http://www.golfgtiforum.co.uk/index.php?topic=68927.0
I didnt want to cut any wires , but handily there are spare switched fuse points on the upper row of the fuse box which is behind the side panel on the drivers side. I have 2 spare. And just use a fuse to hold the wires in.
Offline john_o
« Reply #13 on: 13 February 2008, 22:43 »
There you go Steve  :smiley:
Pic 1 : in the engine bay , battery box on rhs , can see cable running thru bulkhead + the coathanger
Pic 2: in the passengers footwell , with foam under glovebox removed, shows coat hanger again lol
Pic 3 : boost sensor attached to air intake screw (will have to go elsewhere if I fit a carbonio!)
Pic 4 : shows the boost guage fitting kit I bought from forgemotorsport , made it much easier + 2 extra takeoffs if i need them.
Pic 5 : In car at night , I run gauge permanently in 'night' mode , as I find it too bright otherwise.
Offline SteveS
  • GTI ED30
« Reply #14 on: 13 February 2008, 23:23 »
thanks a lot! i will take a look in my car now at the weekend!
the gauge looks lovely!!! how much?
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline neg
« Reply #15 on: 14 February 2008, 08:20 »
Excellent, think I may go for this...
how long was the boost pipe to the controller - just thinking as mine will need to reach the DV where the boost take off is.
Offline Kiddfrost
« Reply #16 on: 14 February 2008, 11:20 »
I threaded my laser unit cable through the grommet that sits behind the battery area. I did not need to take anything out except that thin foam sheet which sits underneath the glove box. All I did was poke a metal coat hanger wire from the inside and it came out near the side of the battery. Tape the cable to the coat hanger and pull it through very slowly.
couldnt get ne pix could you?
Was gonna do some at the weekend but I guess you dont need them now..
Offline john_o
« Reply #17 on: 14 February 2008, 12:04 »
£40 for pod , £140 for the guage , quality costs!
Offline john_o
« Reply #18 on: 14 February 2008, 12:08 »
Its up to you where you place the sensor in relation to the boost takeoff point.
Diff between ED30 (relocated DV to front of engine , virtually same place as I took feed from) and std GTI  (DV at back)
Kept it short for response reasons , but this has to be balanced with a good place to mount sensor.
Im still not convinced my position is best tbh.
When I remap + get forge DV (which has the boost take off) , I may switch to taking my boost feed from there and returning OE pipe back to normal , then I could sell the forge boost fitting kit :-)
Offline SteveS
  • GTI ED30
« Reply #19 on: 17 February 2008, 17:30 »
ok well i had a look today.
i took the foam bit off with the two thumb screws. i can see the fab cables going though,
looked in the engine bay and can kinda see where it comes out, however the gap is soo small. i have small hands so god knows how you managed it... for 0awg cable i have i think i need more space.
i tried poking some wirethough but it wouldnt go. i guess u had to push hard to make a hole though whatever is there??
SteveS
