Author Topic: infrequent stiff steering  (Read 2152 times)
Offline cняis
Re: infrequent stiff steering
« Reply #10 on: 11 February 2008, 20:51 »
on the bottom of the steering rack, u will need to jack the car up.
looky here:
http://www.iol.ie/~kilkennyhockey//BentleyManual/SU01/ch7.2.5.html
you can get to it by looking up towards the rack from behind the o/s/f wheel
also, imagine that picture in reverse (as yours is RHD unlike the pic)
Offline golf mk2 tornado red
  • same s**t just another day
« Reply #11 on: 11 February 2008, 21:03 »
sweet sorry for hijacking .tomorrow it will be .i live on a cobble road its a bloody nightmare
Offline cняis
« Reply #12 on: 11 February 2008, 22:21 »
wish mine was more like yours, i have the opposite problem  :sad:
« Reply #13 on: 13 February 2008, 12:55 »
I agree with golf8v, sounds like top mounts to me, and check the springs are seated in the struts properly.
Offline cняis
« Reply #14 on: 13 February 2008, 14:36 »
kthanx  :smiley:
how do i check the top mount bearings for wear/seizure?
« Reply #15 on: 13 February 2008, 14:58 »
jack it up both sides and spinthe wheel, see if you can spot rough/stiff movement :)
Offline cняis
« Reply #16 on: 13 February 2008, 15:06 »
did that and it felt fine.
confused now.
seems like its only a problem if there's weight on the steering/suspension components. (especially slow turning such as parking/turning the car around). its no problem at speed.
 :lipsrsealed:
« Reply #17 on: 13 February 2008, 15:10 »
hmm, maybe they only bind when under load.  any play in the top mounts?
Offline cняis
« Reply #18 on: 13 February 2008, 15:23 »
will check when i have chance, is this just a case of popping off the strut top caps and having someone turn the steering wheel whilst i check for play?
« Reply #19 on: 13 February 2008, 15:57 »
yeah, and wiggle the strut about too.  Note there will be movement bwtween the top mount and shock tower, becasue the only thing holding them in is gravity, what you're looking for is play in the actual bearing :)
