Author Topic: Got no horn  (Read 4460 times)
Offline Johnny.A
Re:Got no horn
« Reply #10 on: 21 April 2004, 23:59 »
One thing to check is the metal leaf spring on the indicator switch that comes into contact with a metal ring on the wheel. These often get gummed up with all kinds of crap and prevent the horn from working, and sometimes they fall off/break.
Look at the bottom of the steering column between the wheel and ignition shroud, you should be able to see it there.  get something pointy and clean out the crap stuck there and give it another go!
Also try removing the centre cover for the steering wheel and make sure both wires are connected to the push horn, and also try touching them together when the ignition is on to see if its your push horn that is the problem.
This what happened on my moms mk3 gti!!!!
Offline bigsteve
Re:Got no horn
« Reply #11 on: 23 April 2004, 17:58 »
Still haven't sorted this out, but haven't really had a chance to be honest.   A friend of me girlfriends dad had a quick look, says that I appear to be missing a relay!!
Just popped to the local auto shop, they haven't got any relays in stock so have to try the other place tomorrow.
Here's hoping.  Plus am now finally insured.  Taking baby out for spin tomorrow.   ;D
