Golf mk3
hardmonkeys
winding back caliper piston without the propper tool?
Topic: winding back caliper piston without the propper tool? (Read 4183 times)
remapped
If you are going through Hell, keep going
Re: winding back caliper piston without the propper tool?
Reply #10 on:
10 February 2008, 20:53 »
ok i know its made buy ......... laser
but it works when the nipple is lose was £19.99 at crudfords
laser part no.1314
halfruds part no. 694661
OEM(ish) G3GTi 8v5dr
kells
Guest
Reply #11 on:
10 February 2008, 21:07 »
thanx for the pic and part numbers, will go tomo, does it work well ??, easy to use??
remapped
Reply #12 on:
10 February 2008, 21:12 »
Quote from: kells on 10 February 2008, 21:07
yea works ok just lots of swearing and some minor hand cuts.
kells
Guest
Reply #13 on:
really?
remapped
Reply #14 on:
10 February 2008, 21:16 »
lol yea then you loosen the nipple get fluid every were and the swearing stops !
joking aside its easer to take of the rear off discs remount the caliper and bracket and use a spanner or socket to aid you .
Last Edit: 10 February 2008, 21:18 by remapped
kells
Guest
Reply #15 on:
10 February 2008, 21:18 »
so do u loosen the nipple first is that what your saying??
then attach this device and wind it in?, am i right in saying its clockwise you turn it?
remapped
Reply #16 on:
10 February 2008, 21:20 »
i loosened the nipple just before winding the caliper back
hey i menber seeing a guide on here !! which i used to aid me
remapped
Reply #17 on:
thats the one
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/rearbrakes/index.htm
Last Edit: 10 February 2008, 21:24 by remapped
kells
Guest
Reply #18 on:
10 February 2008, 21:41 »
cool, well done all that in the link already, jus need to wind back the caliper and fit the new pads
Golf mk3
hardmonkeys
