Author Topic: I feel like a BMW driver (No Indicators!)  (Read 2303 times)
Offline Tom H
  • Previously board-stupid! :D
Re: I feel like a BMW driver (No Indicators!)
« Reply #10 on: 11 February 2008, 09:40 »
How did you get on Tom?
Also, with me it cant be the stalk as when the engine is off, keys are removed etc, flicking the stalk left puts the left parking lights on and flicking it right puts the right parking lights on...
You should try that also tom before changing it (if it comes to that) does anyone know why else just one signal would stop working...? It cant be the stalk, it's not the fuse and surely cant be the relay as the left side still works... :undecided:
Matt.
So far I've bought a new relay (went halfords in the end, I had loads of running around to do this weekend so I had to use the fast and easy but expensive option!) My plan at the moment is to wait for them to stop working again so I can then change the relay and I figure that should give me the definative answer so know that it was that - and I'll try you test to see if the stalks the problem - I hadn't thought of that!
Offline mattoligy
« Reply #11 on: 11 February 2008, 14:18 »
Kool, well i found my problem and now its fixed :grin: it may be the same for you.
Behind the fuse box there is a "Green" plug, it does both signals, theres 2 wires going in each side and one of mine was loose...
Maybe worth checking it yourself tom.
MKIII Golf Cabrio 2.0L ~ Black Leather Heated Seats ~ Air Con
Offline Tom H
« Reply #12 on: 11 February 2008, 14:41 »
I'll give it a look, thanks. My first thought was maybe a loose a connection as it keeps fixing itself but wasn't sure where to look for one!
I completly forgot until I was driving around in the sunshine this weekend that I was supposed to get a new sunroof motor about 6 months ago too! Opps!
