Author Topic: golf mk3, USING TOO MUCH FUEL!!  (Read 7118 times)
Offline golfmk31993
Re: golf mk3, USING TOO MUCH FUEL!!
« Reply #10 on: 05 February 2008, 21:29 »
are they easy to fit?
im no mechanic but i do like to have a go if its not too hard a job
thanks
« Last Edit: 05 February 2008, 21:37 by golfmk31993 »
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 05 February 2008, 21:40 »
unclip wires and pull the old one out...slot new one in ,wire up and its done...no tools needed!!
just make sure the engines cold!!
Offline golfmk31993
« Reply #12 on: 05 February 2008, 21:42 »
ok sounds easy enough, just gotta figure out were exactly its located , wot does it look like? so i know wot im looking for
  • Back in a Mk3...
« Reply #13 on: 05 February 2008, 21:46 »
its in the top hose at the front of the engine... i would post a pic but photobucket isnt working!
Offline golfmk31993
« Reply #14 on: 05 February 2008, 21:52 »
if u could send me a pic when u can id really apreciate it, itll take me a day or so to get the new temp sensor,
any idea how much i should pay for the sensor?
  • Back in a Mk3...
« Reply #15 on: 05 February 2008, 22:04 »
picture wemailed....and should cost £8-12 to buy
Offline golfmk31993
« Reply #16 on: 05 February 2008, 23:28 »
hi i have recieved the diagram but im a little confused,,
wich temp sensor is it that i want to replace???   the ecu temp sensor or the inlet manifold temp sensor??
thanks
Offline golfmk31993
« Reply #17 on: 06 February 2008, 19:30 »
i orderd the sensor today, little bit more expensive than i thought £23.50, should be here on friday so ill fit it then and let u know how it goes
Offline kr1s77
« Reply #18 on: 07 February 2008, 15:26 »
DONT put a 2hnd one in get a gen VW one they only a few quid..I got a GFS one 1st and that was a duffer...
apart from no difference in running, how did you know it was a duffer..
ASV 1.9 TDI 110
Offline Dragon6
« Reply #19 on: 07 February 2008, 18:51 »
because it used loads of juice plugs where black and the oil stank of petrol.Put in another temp sensor and all was fine couldnt think of anything else it could be and as it was a 2min job tried that 1st.Then took it to the local garage who checked it over just to be on the safe side and was all ok
