Author Topic: Mk3 2.0 8V water leak please help!  (Read 2189 times)
Offline madmanmavis
« on: 04 February 2008, 17:18 »
Hi guys
Ive noticed a water leak on my 8v ive attached pis can anyone shed any light on the part thats leaking so i can try and replace tommorow
Any help really appreciated.
Cheers Matt
Offline stefgolf
Re: Mk3 2.0 8V water leak please help!
« Reply #1 on: 04 February 2008, 17:24 »
looks like its coming out of the housing where it seals to the block hope this helps.
Offline madmanmavis
« Reply #2 on: 04 February 2008, 17:30 »
Yeah i was just wondering what that bits actually called? and if it has a gasket? I need to run down to london thursday and could do with sorting it before then!
Offline Uruk Hai
« Reply #3 on: 04 February 2008, 17:34 »
Its called the cylnder head flange and they go for a pass time, your better off getting a geniune one as I've just found out  :undecided:
Offline madmanmavis
« Reply #4 on: 04 February 2008, 17:43 »
Do i want to know how much? was it hard to fit? there looks to be a sensor in there?
Im assuming fairly simple job just a case of draining old coolant etc and replacing?
Cheers Matt
Offline Uruk Hai
« Reply #5 on: 04 February 2008, 17:57 »
There are two sensors in there (ECU temp sender and Temp gauge sender) all you do is take them out, take off the hoses and then remove the plastic flange. Then its a case of cleaning up the surface of the head as much as possible and putting the new one on, refitting all the other bits and then refilling the cooling system. I would be supprised if a genuine one cost more than about 10 or 12 quid
« Last Edit: 04 February 2008, 17:59 by Uruk Hai »
Offline madmanmavis
« Reply #6 on: 04 February 2008, 17:59 »
Thank you sir, so im advised to replace with genuine? is there a gasket to replace as well?
Offline Uruk Hai
« Reply #7 on: 04 February 2008, 18:03 »
You should get a rubber O ring with it, and I would get a genuine one as I replaced the other flange thats on the end of the head with a non genuine part and it lasted about 12 -14 months so now I've got to do it again so I bought a geniune this time and should of the first time. Make sure that the area where the flange bolts to head is clean and flat, good luck  :smiley:
Offline madmanmavis
« Reply #8 on: 04 February 2008, 18:05 »
Thanks again ill pop into VW tomorrow and try and get the part i need
Cheers Matt
Offline madmanmavis
« Reply #9 on: 05 February 2008, 15:38 »
All sorted cheers for the help
£15 in bits and £5 in coolant, replaced the springy rad clips with jubilee clips as well.
birmingham VW place had all parts so thumbs up for them :smiley:
