Golf mk3
hardmonkeys
Engine noise... Tappets, Cam belt...?
4
Topic: Engine noise... Tappets, Cam belt...? (Read 9012 times)
Len
10k hero
Re: Engine noise... Tappets, Cam belt...?
Reply #20 on:
05 February 2008, 13:01 »
Oil is slightly thicker when its cold so another indication its tappets.
Its not a difficult job but means head off etc. Plus you need good valve compressors and a good safe, flat clean area to work on.
www.sas.org.uk
www.the-ace.org.uk
mattoligy
GTI forum regular
Reply #21 on:
05 February 2008, 13:18 »
What, you reckon i can do it myself
lol
MKIII Golf Cabrio 2.0L ~ Black Leather Heated Seats ~ Air Con
Len
10k hero
Reply #22 on:
05 February 2008, 14:04 »
Only if you got the right tools, but yea its a simple enough job.
Need some good sturdy tools to undo head bolts though!
www.sas.org.uk
www.the-ace.org.uk
mattoligy
GTI forum regular
Reply #23 on:
05 February 2008, 16:04 »
I got a nice big strong socket set, screwdrivers etc etc but no specialist tools!
lol
So is that enough!? Or do i need a certain tool? Also, shall i replace them with new! Or used...
Would anyone be able to (if uv got time that is) knock me up some sort of guide!?
Thanks, Matt.
Len
10k hero
Reply #24 on:
05 February 2008, 16:30 »
Gonna need a bit of a list!
Torx head bits set
Hex head bits set
1/2" drive socket set
Long drive bar (for head bolts)
Torque wrench to tighten head up again.
Valve spring comoressor.
Get a Haynes manual and follow that!
www.sas.org.uk
www.the-ace.org.uk
Abz585
Just got here
Reply #25 on:
05 February 2008, 18:12 »
daft i know but one of the pullys is not catching on the plastic covers is it cause it dont sound like the big end or a tappet to me cheers
mattoligy
GTI forum regular
Reply #26 on:
05 February 2008, 18:29 »
i'v had the top part of the cover off and it still does it! not sure how to get to the bootom part lol, the sound is coming from the left/middle of the engine RIGHT near the spark plugs and at about that level, thats why i thought it may be ht leads..
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Reply #27 on:
you dont need the head off to change the tappets, you need to lift the camshaft off the head and pull each tappet out from its bore. Then drop in a new one. The head stays where it is and you dont need valve spring compressors, the valves stay put.
Its a simple job which can be done with a good socket set and little more. It will envolve re-timing the camshaft etc and if you have done or know how to do a cambelt it shouldnt be a problem. A haynes manual will be very usefull
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
mattoligy
GTI forum regular
Reply #28 on:
05 February 2008, 18:33 »
Nope never none a cambelt
lol, how much do you reckon a garage would charge?
Matt.
Rmachines
Reply #29 on:
05 February 2008, 18:37 »
I would charge arround £100, depends though, try lifter treatment first, its quite possible you have sticky lifters! Go and stick a bottle of treatment in with the oil, it stays in untill the next oil change, costs £7 ish.
4
Golf mk3
hardmonkeys
