Author Topic: door membrane  (Read 3568 times)
Offline gibby
Re: door membrane
« Reply #10 on: 03 February 2008, 15:03 »
I went overkill on mine, I did the same as the pic above, plus I also did the holes to the top left and right to start with, then I got the old membrane and stuck it to a new membrane so it was double thick and then duct taped it all to the door.
......now officially dubless.
Offline Steve_B
Re: door membrane
« Reply #11 on: 04 February 2008, 10:35 »
Just used UHU or something like that if I remember rightly. The most important thing is to make sure its all clean first imo. White spirit did the trick for me.
Offline mk2mark
Re: door membrane
« Reply #12 on: 04 February 2008, 16:48 »
The other thing that really works is if you duct tape the inside of the holes up to about halfway, that way you've tape on tape so it sticks better, and when water gets to the lower lip there's a flashing rather than relying on just the sticking power of the tape. Lay it from top to bottom (and bottom to top for the inside layer) so you get a roof-slate effect.
Offline richard s
Re: door membrane
« Reply #13 on: 07 February 2008, 20:39 »
the sticky black ribbon is called butlyn tape and ours at work is supplied by a company called wurth but i would try a local autopaint supplier
Offline midz16v
Re: door membrane
« Reply #14 on: 08 February 2008, 09:31 »
thats the very stuff i'm after i'l try the paintshops then.
cheers
Re: door membrane
« Reply #15 on: 08 February 2008, 11:16 »
Blaze im gonna steal your pic if you dont mind, I always need one when im trying to explain this to peeps but ive not found one till now :grin:
In addition to what everyone has said, look closely along the bottom of the door in blaze's pic.  See the 2 small holes? (not the lower ones for the door card clips)  Make sure you DONT block those when you fit your membrain, if you doo, water cant drain and sits at the bottom, no matter how well you seal it if that happens it will seep through eventually!
The 2nd sheet stuck to the bottom of the door trick works well to prevent this from even happening though, as any water that gets in is deflected off that sheet and never ends up in the bottom of the outer sheet.
Edit: I've always used waterproof duck tape, never had any leaks.  Done it on 4 cars so far :)
« Last Edit: 08 February 2008, 11:18 by rubjonny »
Offline Gernster
Re: door membrane
« Reply #16 on: 08 February 2008, 12:47 »
ducktape, cleaned paintwork with petrol and heated up surface & tape with hairdryer. In this weather the tape/ metalwork is too cold to adhere properly, so heat it up first to activate the glue.
Gernster - GTi-TD
Blazing Storm
Re: door membrane
« Reply #17 on: 08 February 2008, 17:33 »
Sure rubjonny, use my picture. You suggested the whole idea to me in the first place anyway. :smiley:
Offline Thom89
  • Looking for an "Icebreaker"
Re: door membrane
« Reply #18 on: 08 February 2008, 19:49 »
Sorry to be a bore, but only use petrol to run your car with! NEVER use it as a cleaning agent, its far too volatile, one static spark, and its game over, parafin, or white spirit are more suitable, but not ideal...
Tom
Re: door membrane
« Reply #19 on: 08 February 2008, 21:09 »
ta  :wink:
