Author Topic: Metallic Rattle/ Knocking Noise  (Read 5478 times)
Offline J5H VW
« on: 31 January 2008, 10:55 »
Guys, this has bugged me for a while, but seems to have gotton worse now.  :angry:
I have a metallic sounding rattle/knocking on my car.  Its noticable when:
- I first start up (but that could be linked to the next point)
- I blip the throttle slightly (800 -> 1200 rpm)
- When I go over a bump in the road.
Any ideas?  Someone once said its the middle exhaust bracket.  Is this correct?  :huh:
What choices do I have?  Also, what else could it be?  Really starting to bug me.  :angry:
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
Offline Ashmond
  • Money, b!tches And Boost
Re: Metallic Rattle/ Knocking Noise
« Reply #1 on: 31 January 2008, 10:56 »
Most likely to be your exhaust bracket if not check engine mounts.
Offline J5H VW
« Reply #2 on: 31 January 2008, 11:03 »
How can I check those without a ramp?
Where is the exhaust bracket located (where abouts on the exhaust should I be looking)
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« Reply #3 on: 31 January 2008, 11:04 »
You could also try any heat sheilds too.
 :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 31 January 2008, 11:04 »
could be the cat heat shield, the spotwelds crack and makes a tinny rattle at certain rpms, fairly common
edit: someone beat me to it ^
Offline J5H VW
« Reply #5 on: 31 January 2008, 11:09 »
lol - racers on the road, racers on the forum!
Offline J5H VW
« Reply #6 on: 31 January 2008, 11:14 »
Is it just a case of squeezing under the car and trying to rattle the heat sheild round the cat, and the one at the back of the engine bay?
If it is this, is a re-weld the only way to fix it?
What if its the exhaust bracket?
« Reply #7 on: 31 January 2008, 11:16 »
Get a trusted friend to sit in the car and give it a rev while you listen.
If its a heat shield just rip it off. Thats what iv done.
If its the rubber mount i think you can get another. if its the bracket its self you need a welder i think.
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 31 January 2008, 11:17 »
Get under the car and have someone start it, see if you can locate the source. if its the exhaust bracket, just grab a new one from GSF or eurocarparts. If its the heat shield, you can either get someone to put a couple of weld spots next to the broken ones, try bodging it with some exhaust sealant paste, or just rip the heat shield off altogether (just don't park on tall dry grass when the exhaust is hot :grin: )
Offline J5H VW
« Reply #9 on: 31 January 2008, 11:24 »
... or just rip the heat shield off altogether (just don't park on tall dry grass when the exhaust is hot :grin: )
So is the heat shield located between the cat and the road? :huh:
I thought the heat shield would be above the cat, so it would be between the exhuast and the underneath of the car?
