Hi,
Just a wee question to those of you with aftermarket headunits.
Have any of you managed to retain the feature where by the headunit stays on when you switch the engine off but leave the key in the ignition?
From what i've gathered so far, even with a CAN-BUS adapter, it seems you have to take a switched ignition, usually from the lighter socket, but this immediately drops out when you turn the ignition off so if you want to sit in the car with the headunit on you have to have the ignition on which isn't ideal.
Any advice or info much appreciated
Kenny
