Author Topic: what tools?  (Read 2813 times)
Offline dabill
what tools?
« on: 29 January 2008, 13:25 »
righty, found some 16v mk2 hubs im wanting, just gotta take them off my self.
only got an hour to do this 2morrow afternoon, so wat tools will i need.
they have the two bolts on the suspension leg, the two small ones on the ball joint, the track rod ends, and it will need splitting from the drive shaft. but i dont have the tool for splitting the drive shaft from the hub, where can i get this?
what size socksts will i need? guessing i'll need stacks of plusgas too!
cheers in advance,
rob
noble tuned - and still not fast enough!
Offline tobz.
Re: what tools?
« Reply #1 on: 29 January 2008, 15:56 »
the hub nut is 30mm, you'll ideally want a 3/4" drive socket and a HUGE breaker bar.
You'll probably need to do it with the wheels on the car with it on the ground and somebody standing on the brakes.
You got any pics of your dad's split ?
Offline dabill
Re: what tools?
« Reply #2 on: 29 January 2008, 16:05 »
ahh... that could be a problem, its in the scrappies and it dont ave wheels... might have to jam a screwdriver down the vent holes on the discs to get the fooker off. sure i have a 30mm socket somewhere :S
the two nuts on the suspension leg? are they 15 or 12 mm? or neither?
im guessing i'll need that tool rubjohnny was on about in another post for splitting the track rod ends off?
cheers, rob
Offline tobz.
Re: what tools?
« Reply #3 on: 29 January 2008, 17:08 »
Hmmm if it doesn't have wheels, isn't on the ground and the brakes don't work you'll do well to get it undone without an airgun. Probably easier to split the outer cv joints although then you'll have no hope of getting the nut undone to remove the remaining bit of driveshaft from the hub.
I'm pretty sure the bolts through the bottom of the shocks are 17mm.
Offline JimR
Re: what tools?
« Reply #4 on: 29 January 2008, 18:33 »
They are 17mm yes, and what tobz said about the hub nut, you jam a screwdriver in the brake vent and either the brake disc or the screwdriver will break before the nut undoes, trust us on this.
Mk2 GTi.
Offline amgine
Re: what tools?
« Reply #5 on: 29 January 2008, 20:56 »
I agree,
Hub          30mm I'm sure if use use a decent screw driver in the disc vent and a long lever on the socket you'll be ok.
Susp Legs  17mm. use two though cos the bolt often spins...
Trackrod    ??15mm?? but defo use a splitting tool once the nut is off.
goodluck.
rub'a'dub dub
Offline dabill
Re: what tools?
« Reply #6 on: 30 January 2008, 09:20 »
right guys, got a big decent screw-driver so hopefully should be ok... got a hub splitting too aswell, along with a trac-rod-end splitter thingymabob.
was wondering, what torque are the nuts done upto on a hub?
Offline tobz.
Re: what tools?
« Reply #7 on: 30 January 2008, 09:45 »
265nm!!! good luck
Offline dabill
Re: what tools?
« Reply #8 on: 30 January 2008, 10:08 »
holf mother of mary! well, its a good big screwdriver and i have a pretty big breaker bar... hope i manage it, just need to figire out which was the turn the nut haha!
Offline monkeyalan
Re: what tools?
« Reply #9 on: 30 January 2008, 10:26 »
this that valver at jays?
if so , you are mental ! good luck  :laugh:
