Author Topic: NOS  (Read 2938 times)
Offline 1688bran
Re: NOS
« Reply #10 on: 29 January 2008, 12:19 »
Just do some research into which type of NOS kit is best for the Golf.  Dry or wet??
With the GTi-6's, wet kits are the way forward. :wink:
I think your best off speaking to some tuners.
Which turbo engine have you got?
Have you also sorted your suspension( inc. rear ARB)/brakes out?  Having a sorted susp. setup can be like having an extra 50 bhp (improves your point-to-point pace).  Do you do track days?  You could also get some instruction from some qualified curcuit instructers who will teach you how to extract the maximum out of what you've already got!!  :wink:
 gonna get coilover but hvnt decide which one to go for .... already upgrade the brakes got brembo discs and green stuff pads ... never done a track day wouldnt mine tho ,thinkin of doin it durin the summer time . i got the AUM ENGINE .
Offline samy_1800_turbo
Re: NOS
« Reply #11 on: 29 January 2008, 12:45 »
i fink wid nos u will need to lower the compression ratio as using nos it will make your engine run learn and can cause the engine to knock (pinking) which ant good  lol
Offline Ashmond
  • Money, b!tches And Boost
Re: NOS
« Reply #12 on: 29 January 2008, 12:53 »
I would just go bigger turbo rather than nos tbh
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: NOS
« Reply #13 on: 29 January 2008, 13:05 »
Me too.
IIRC, I think even the small bottles used to be £85 a refil!! :shocked:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Ashmond
Re: NOS
« Reply #14 on: 29 January 2008, 13:11 »
Fork out for a bigger turbo and then you got more power all the time!
Offline richw911
Re: NOS
« Reply #15 on: 29 January 2008, 18:28 »
Offline AlanD
  • MK5 2.0T 16v
Re: NOS
« Reply #16 on: 29 January 2008, 18:35 »
Ah, to have a bottomless pit of money :(
