Author Topic: MK3 lower vents  (Read 124627 times)
Offline jafo
Re: MK3 lower vents
« Reply #270 on: 17 October 2008, 17:07 »
Hey where can i get my hands on a set of these??
Offline Shady Pioneer
  • graphic designer.
Re: MK3 lower vents
« Reply #271 on: 18 October 2008, 10:21 »
When a bought some a quite some time ago I never actually put them on my car, they wouldn't fit properly and stay in place, what are the chances of a refund?
Offline Mikester
  • Civic Type R
Re: MK3 lower vents
« Reply #272 on: 18 October 2008, 11:40 »
Ive had 2 or 3 sets, and they fitted fine. But im sure he will sort you out somehow.
  • graphic designer.
Re: MK3 lower vents
« Reply #273 on: 18 October 2008, 11:44 »
I dunno if it's their fitment, because the standard grills fit and snap on piece of cake, but these just won't stay :(
Offline Mikester
  • Civic Type R
Re: MK3 lower vents
« Reply #274 on: 18 October 2008, 11:56 »
They are tight, you have to really pushed them to snap on, took me a good 15mins each side first time.
Second time i had a 2nd bumper and smoothed them in and sprayed them haha. no problems then ;)
Offline bored_Welsh_lad
Re: MK3 lower vents
« Reply #275 on: 18 October 2008, 16:45 »
I found the easiest way to put them on is to get under the bumper and look from the underside of the engine bay you can locate the tabs from there.. if there are issues, post them back to me and ill sort you out with a refund
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
  • graphic designer.
Re: MK3 lower vents
« Reply #276 on: 18 October 2008, 20:35 »
I did get on the underside matey, it was on a ramp at my friends lol! It's just not staying in place, like, two will clip but the other two won't making it wonkey.
I'll PM you later to sort out sending them back if that's cool?
Re: MK3 lower vents
« Reply #277 on: 18 October 2008, 22:03 »
I picked up a pair of FK ones the other day, not sure if it helps but I had to trim the bumper and they were a very tight fit.
Offline vwnutant
  • dubbin since 1990
Re: MK3 lower vents
« Reply #278 on: 18 October 2008, 22:40 »
Please can i get a set of these look really neat !
pm/email me details and payment etc
thanks
ant
====VWNUTANT====
===ADMIN AT UKPASSATS===
MK3 GOLF FOR THE MRS ........1.4C
Offline jafo
Re: MK3 lower vents
« Reply #279 on: 19 October 2008, 10:00 »
Get some of these on fleabay!!!
