Author Topic: MK3 lower vents  (Read 124846 times)
Offline bored_Welsh_lad
Re: MK3 lower vents
« Reply #210 on: 03 May 2008, 00:15 »
This was answered earlier in the thread i think...
basically you need to undo the horn slightly and rotate it, it should allow you to fit them then without any issues...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
Offline Shady Pioneer
  • graphic designer.
Re: MK3 lower vents
« Reply #211 on: 03 May 2008, 00:17 »
I know about the horn, that's not the problem lol! It's just (imagine looking at the car and then the right lower vent) the bottom left of the vent doesn't fit properly, as if it doesn't clip in. I haven't had a proper change to get under but just wondering anyone knows any tips? lol!
P.S. BWL...thanks for the vents man, hell of a quick delivery  :tongue:
Re: MK3 lower vents
« Reply #212 on: 03 May 2008, 08:47 »
When i did mine they were quite tight, i ended up jacking up the car and working from inside the front bumper...used a light to see where the clips were going to locate and use a flat head to prise them on..
Bumper Vents :D
Offline dubsport
  • TDI POWAR!
Re: MK3 lower vents
« Reply #213 on: 08 May 2008, 19:25 »
cheers for the vents mate ... finally got them to fit properly  :grin:
Re: MK3 lower vents
« Reply #214 on: 10 May 2008, 12:06 »
hey dubsport. if you notice it isnt sitting perfectly flush with the top, you can take a mm or 2 out of the clips on the back and it should sit better..
Bumper Vents :D
Offline Mikester
  • Civic Type R
Re: MK3 lower vents
« Reply #215 on: 10 May 2008, 12:56 »
i only have one vent now  :sad:
Re: MK3 lower vents
« Reply #216 on: 30 July 2008, 19:50 »
bump
Bumper Vents :D
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: MK3 lower vents
« Reply #217 on: 02 August 2008, 01:38 »
Is there any possibilty i could make an order for a set of these vents please, is it just a case of sending funds over by Paypal ?
Cheers.
« Last Edit: 02 August 2008, 01:41 by thai-wronghorse »
Re: MK3 lower vents
« Reply #218 on: 03 August 2008, 20:32 »
 yeah mate, done through paypal normally...
£20 to bored_Welsh_lad@hotmail.co.uk could you mark it up as a gift also so we dont get nailed with charges??
Dicky
Bumper Vents :D
Offline Geeman
Re: MK3 lower vents
« Reply #219 on: 04 August 2008, 13:22 »
I'll take a set of these please.
Will zap across a PayPal payment as soon as you let me know you've got a set to send me...
Cheers,
Giles
