Author Topic: Sudden MPG drop on my 2.0 GTi???  (Read 3236 times)
Offline rickyk
« on: 22 January 2008, 18:01 »
My 1999 Golf 2.0 GTI has recently had a sudden mpg drop, it was reading about 35mpg on a steady motorway run now it has dropped suddenly to around 20-25mpg what could cause this??  :embarassed: thanks ricky
« Last Edit: 22 January 2008, 18:08 by rickyk »
Offline GTi-Matt
Re: Sudden MPG drop on my 2.0 GTi???
« Reply #1 on: 22 January 2008, 18:36 »
hi there ive got a 2.0 litre 2, were u on the motorway when it dropped or just around town?
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline rickyk
« Reply #2 on: 22 January 2008, 18:45 »
The motorway i think, i just noticed the reading was alot lower than normal, and it seem to give readigs more often.
Offline GTi-Matt
« Reply #3 on: 22 January 2008, 18:51 »
if you sppeded up that would cause a drop in mpg if not then i suggest take it to your local garage and just ask them to put it on a fault n code reader and see if you had a problem. maybe a sensor at worst.
let us know how you get on mate
Offline rickyk
« Reply #4 on: 22 January 2008, 18:52 »
How much would that set me back?
Offline GTi-Matt
« Reply #5 on: 22 January 2008, 19:14 »
dont hold me to it maybe £50-£60 depends if u go to the main stealers!!! i dont think theres a charge 4 using the fault reader ive never paid anyway and ive used it twice
Offline rickyk
« Reply #6 on: 22 January 2008, 21:15 »
i have just noticed that it seems to have developed and slight missfire/lumpyness in the revs??
Offline Lennon
« Reply #7 on: 22 January 2008, 22:02 »
Mine did this once, booked it into the garage and a few days later it was fine.
It was running like sh!t, lumpy, 20mpg, even less power than usual.... then suddenly back to normal.
The oil light warning had come on the day before it did this (had only just bought it and not realised how much it used!) but had been filled before it started.
Offline rickyk
« Reply #8 on: 22 January 2008, 22:05 »
any ideas what it was?? coil pack? plugs? just seems to lumpy on idle and now smells like its rich from the exhaust.
« Last Edit: 23 January 2008, 09:08 by rickyk »
Offline rickyk
« Reply #9 on: 23 January 2008, 10:49 »
would vagcom pick up the fault?
