Author Topic: hub nut  (Read 2480 times)
Offline hobbiniho
Re: hub nut
« Reply #20 on: 14 January 2008, 17:03 »
f**kin hell looks like my mechanic friend is going to have fun when he goes to do the front wheel bearings on my car soon  :grin: :grin: rather him than me  :laugh:
Offline Diamond Hell
  • Opinions я Us
Re: hub nut
« Reply #21 on: 14 January 2008, 17:29 »
What's all the fuss about, ya big girls?
These hub nuts are dead easy.
Try undoing the castle nut on the back of a T25 Transporter - they have to be done UP to 350NM.  Now add 20 years and try getting the 46mm nut off.  Me I use 3/4" drive + long pole on them.
2' breaker bar + one fat bloke normally seems to work on Golfs.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: hub nut
« Reply #22 on: 14 January 2008, 18:25 »
Hurray its off very long bar and a bit of jumping, then ping it moved  :smiley: :smiley: :smiley:
Offline jammac
Re: hub nut
« Reply #23 on: 14 January 2008, 19:13 »
CONGRATS!!!!
for future referance if you dont have a bit of scaf pole to extend ya breaker bar you can lean on the bar hard and then smash it at the end harder.
abit of shock loading works lots of the time
at my work we use GT85 penetrant spray oil and its the muts
ITS A TRAP!
Re: hub nut
« Reply #24 on: 15 January 2008, 17:56 »
if you ever plan to do this in future I recommend you pop to halfords and invest in a 30mm impact socket, they fit the nut very tightly and wont slip off as easily as a std 30mm socket will.  Their breaker bars are well worth the money too.  I had to buy both in 1 go when my crappy 12point socket started to slip and my breaker bar exploded trying to do the same thing on my GTI  :grin:
Re: hub nut
« Reply #25 on: 15 January 2008, 19:57 »
I had on of these to hand as you say good tight fit, well worth the money. Noticed that one of the cvs is wobley where as the other one was quite stiff. does the wobly one need changing?
Re: hub nut
« Reply #26 on: 16 January 2008, 08:18 »
did you hear any clicking when driving round corners?
  • Opinions я Us
Re: hub nut
« Reply #27 on: 16 January 2008, 14:25 »
There's a lot of factors that determine whether a driveshaft/joint is tight or floppy - they're much like women in that respect.
Also, if there is a slight 'clicking', or they're a bit tight you may find they just need lubing up - both women and CV joints again.
Do bear in mind that your CV joints won't respond to dirty talk, and please don't confuse CV grease with KY Jelly, the consequences could be disasterous and totally change your thoughts on how 'dirty' a woman is.
I'll get me coat, shall I?
Offline hobbiniho
Re: hub nut
« Reply #28 on: 16 January 2008, 17:06 »
yes  :wink:
