Golf mk2
Knocking on reverse
Topic: Knocking on reverse (Read 658 times)
catflea
Knocking on reverse
13 January 2008, 16:02 »
Hi Guys. First time here.
Got a problem with my Mk2 driver G plate (GTI lookylike)
when reversing there is a knocking coming from (I think the front) I think it might be a CV joint or something like that - but I am not sure any other ideas would be greatly appreciated. I'm planning on getting underneath for a good look soon.
btw, might be a noob but not a novice got plenty of other projects on the go too!
DarnPB
Formerly Darnpistonbroke
Re: Knocking on reverse
13 January 2008, 17:20 »
Could be your exhaust. Look at that first. The rubbers may be in bad shape or missing causing more movement in the exhaust system than there should be, and its knocking on the body.
catflea
13 January 2008, 17:22 »
The exhaust is loose - needs a rear rubber - its got a bodge at the moment where I work out where to get another, but surely that would manifest itself going forwards too?
Its a kinda clicky noise, not the type of noise you'd expect from an exhaust
JimR
GTI forum regular
13 January 2008, 17:48 »
Maybe a CV joint? Check the rubber gaitors at either end of both drive shafts for splits.
Mk2 GTi.
catflea
13 January 2008, 18:04 »
I was thinking CV but not got underneath to have a look - is it a big job to sort them on these?
Golf mk2
Knocking on reverse
