Author Topic: Engine Timing Question  (Read 1746 times)
Offline mk2mark
Re: Engine Timing Question
« Reply #10 on: 14 January 2008, 21:07 »
The tescos stuff over there is quite good apparently!
« Reply #11 on: 15 January 2008, 17:59 »
indeed, on older/not clever ignition systems (e.g. k-jet, carb) using good fuel you can run more than the factory 6 degrees advance, which will increase the cars performance.  However try this on a Digifant 8v and you wont get far.  This is because the ECU automatically advances the ignition as far as possible, untill it detects knocking/pinking :)
Offline mk2mark
« Reply #12 on: 15 January 2008, 22:45 »
Yeah was going to say I was wrong about that, read it in your tuning guide today!
« Reply #13 on: 16 January 2008, 08:14 »
wrong about what?  Everything you said was correct when talking about a 16v ;)
