Golf mk4
Wazzzer
More Starting Troubles
Topic: More Starting Troubles (Read 2552 times)
Chris 'N' Jen
Here all the time
MK4 2.0 GTi 8v in black (the best colour)
08 January 2008, 15:07 »
Hey Y’all
I got more starting troubles.
Here’s original thread.
http://www.golfgtiforum.co.uk/index.php?topic=69598.0
Like the post says after the garage did whatever they did to the throttle body, if indeed they did do anything to the throttle body. I had the oil, filters and plugs changed. 4 days later and here we are again, difficult starting from cold. Also this morning I had 2 warning lights illuminated. One being the ESP light on the dash (the ESP was on at this time) and the exhaust light which I’m lead to believe is a general error light. Is it something to do with the MAF sensor not working correctly.
I presume I need a lead to a laptop to read these codes. Where might the best place to get said lead?
AlanD
Serious forum addict
MK5 2.0T 16v
Re: More Starting Troubles
08 January 2008, 15:25 »
I belive the best place to get them from is the offical website (
http://www.ross-tech.com/index.html
) as the ones on ebay can be a bit dodgey. You will also need VAGCOM. I think the free version allows you to read and reset error codes, not too sure. Someone please confirm
Your best place to start is getting these error codes and then taking it from there. Sounds like your having a bit of a mare with your car mate
Kinetic Tuning - South Wales
Tuning Werkes - South London
R-Tech - Leicestershire
Carbon Chip Tuning - Manchester
Chris 'N' Jen
Here all the time
08 January 2008, 15:42 »
Cheers for the link mate. Looks like ill be needing one. Just hope i havent bought a knacker as cant really afford to change. Looks like the ESP light has now gone out and is back to normal but the other still remains.
AlanD
MK5 2.0T 16v
08 January 2008, 15:46 »
I dont have ESP on mine so I might well be talking out my arse here, but I thought that the light is either always on or off (fooking obviously) but it either means the ESP is on or off and not actually a problem.
Ashmond
Money, b!tches And Boost
08 January 2008, 15:59 »
I have no idea, but try ringing 0208 681 0208 and ask for Reuben, he may have an answer for you!
Chris 'N' Jen
Here all the time
08 January 2008, 16:28 »
You are partly correct.
When the ESP is on the light on the dash is off
When it is active the light flashes
When it is off the light is on
This morning the light was on when the ESP was on. I tried pressing the button incase it had been accidently switched off but the light wouldnt go out.
@ashmond
Is that number for the ESP or the starting troubles?
Cheers Fellas
Ashmond
Reply #6 on:
08 January 2008, 16:32 »
It was for the starting troubles but tbh Rueben is one of two people that I listen to now after being messed about for months by alot of people, he knows what he is talkin about!
Chris 'N' Jen
Here all the time
Reply #7 on:
08 January 2008, 16:36 »
Cheers Mate
Ill ring tomorrow 1pm ish. Should i quote your name when i ring?
Ashmond
Reply #8 on:
08 January 2008, 16:37 »
yeah say Ash doing the 1.8t conversion
Chris 'N' Jen
Here all the time
Reply #9 on:
08 January 2008, 16:39 »
Cheers, Ill update tomorrow afternoon.
Golf mk4
Wazzzer
