Author Topic: Brake calipers  (Read 1763 times)
Offline batman04
Brake calipers
« on: 02 January 2008, 14:53 »
Hi does anyone know the part numbers for new brake caliper dust seals and the caliper piston seal. i need new ones for my calipers that are all nice and clean and powder coated, do VW still do these parts?
Also i donr a MK2 16v brake conversion and need the reservior bottle for the master cylinder do vw still do these or does anyone know where is best to get either of the parts i need. cheers
Happy New Year .
Re: Brake calipers
« Reply #1 on: 04 January 2008, 17:57 »
what calipers do you have, 239, 256, 239+spacer brackets etc etc ;)
You can get the 22mm master cylinder from most VW motorfactors:
http://www.gsfcarparts.com
http://www.vwspares.co.uk
You also need a MK2 brake servo from an 8v or 16v GTI, and some modification.  You gotta remove the clevis pin from the MK1 servo and fit it to the MK2 servo, the threads on the MK2 servo need to be cut down, measure the distance from the hole in the clevis pin to the mounting surface on the servo, and match that diameter on the MK2 servo + MK1 clevis pin :)
