Author Topic: First post (and suprise suprise its a question)  (Read 2048 times)
Offline Honky
« on: 28 December 2007, 16:42 »
Just joined as this looks quite a good forum so here goes!! oh and sorry about the questions from the start but I think this one might be quite simple.....
Below are pics of the wiring that runs from the Thermotime switch and 5th Injector/cold start. But where does it go?? I can't see anywhere on the board that that style of connector could clip into nor do I see any "female" version of that connector to join it into?? BTW its an 83 Golf GTI
I put a live feed onto one of them to test and my 5th injector worked so it must be just some kinda live loop it needs? Help!!!!
Offline [han]
  • Graphic Designer for Haribo
Re: First post (and suprise suprise its a question)
« Reply #1 on: 28 December 2007, 18:44 »
i cant help, but good luck, if you've tried the obvious of looking for the female then i certainly odn't know!!
Blazing Storm
« Reply #2 on: 28 December 2007, 19:36 »
Don't know if this helps but it mentions it might be of some use to late MK1s too.
http://www.golfgtiforum.co.uk/index.php?topic=44637.0
Offline Honky
« Reply #3 on: 28 December 2007, 21:28 »
yeah it kinda has, thanks!  Very useful to have anyway.
It lists the red/black out of C18 as being for: thermo switch for cold start valve (K-Jet f/inj) however this is only one wire and I've got 2 spades in the connector so I might be halfway there!
Offline Honky
« Reply #4 on: 28 December 2007, 21:41 »
Just nipped out to look at this and yes I have a red/black wire coming from C18 thats free and would fit, could it just be one of brown earth connections for the other spade then?
Dinky
« Reply #5 on: 28 December 2007, 23:27 »
http://www.cabby-info.com/electrical_system.htm
any help!? im cr@p with electrics! :undecided:
Dinx :kiss:
« Reply #6 on: 04 January 2008, 17:50 »
there should be a matching plug somewhere, is that the engine or fusebox side of the loom?  I'll have a look at my cabby later on and see if i can spot it
