Author Topic: Temp Gauge  (Read 2495 times)
Offline ub7rm
Re: Temp Gauge
« Reply #10 on: 04 December 2007, 17:15 »
Exactly as above.  The coolant temp doesn't drop to zero because the air con is on.
2020 BMW 128ti
2017 Golf GTD Estate
Offline faisalgti
Re: Temp Gauge
« Reply #11 on: 08 December 2007, 13:57 »
Does anybody have any idea where the temp sensor is or wherabouts so i can change it myself? The problems not been sorted so im gonna replace it. Or even a link to a page which tells u where? Cheers guys
Btw previous posters were right a/c on or off should not affect it
Offline Lennon
Re: Temp Gauge
« Reply #12 on: 10 December 2007, 19:36 »
Mine has started doing something similar now.  It gets up to temperature then drops back down to zero, or 1/4 for a minute or so before going back up.  It still seems to be running okay at the moment though.
Offline cooltt
Re: Temp Gauge
« Reply #13 on: 10 December 2007, 20:03 »
Hello All
It's not just the temp sensor that causes this as i've just fixed the same problem on my 98 gti turbo 1.8.
First stop is change the temp senser which is easy, if it still does it then you have to change the engine thermostat as well.
Don't waste time buying half a dozen temp sensors. I had exactly the same problem on my BMW 318is.
