Back again!
Ok Ive changed the fuel filter and tested the 2 pumps, both are working fine. I noticed the pump under the car is brand new so maybe the car has had similar problems in the past. Tried cranking her again and no joy, just turns over. Oddly it seems more inclined to try and start with one of the injectors out? I took this out to see if there was fuel coming through and its spraying fine.
I think i can now more or less rule out fuel starvation unless theres something else you guys can suggest I check? Took out the plugs one by one and they had a very nice coating of petrol on them so cleaned them up and checked they were sparking which they are. Im putting the coating of petrol on them down to flooding the pistons with trying to start her so much this afternoon!
So once again im well and truly stuck, anything I should be moving on to check now? Maybe she will start once the petrol in the piston has evaporated by im not holding my breath!
And further advice is much appreciated, Cheers
