Author Topic: Rear wiper problem  (Read 1575 times)
Offline sesterfield
Re: Rear wiper problem
« Reply #10 on: 28 November 2007, 02:22 »
Quote
it's a little more involved than that as you have to rotate the little arm 180 degrees otherwise it will sweep down the paint on the boot not the rear screen
eh? unclip the plastic panel, unscrew the bolt (far left) lay wiper flat, align up the part you just unscrewed, (obviously you have to rotate it or it wont lign up) tighten with spanner, clip on plastic panel. it took me 5 minutes mate, if that :huh:
The way you described in your original post sounded like you were referring to just the arm and not the mechanism by the motor  :smiley:
« Reply #11 on: 28 November 2007, 13:28 »
I had this, was the actual motor that was shafted :)
