Author Topic: water under the seat and oil on the floor  (Read 3734 times)
Offline k33p it low
Re: water under the seat and oil on the floor
« Reply #10 on: 01 December 2007, 04:37 »
Well, I guess I will have to weld it up then, if my mate lends me his welder :rolleyes:
I really dont look forward to taking the windscreen out to do that.
this afternoon i sat in the car with my torch when it was raining and discoverd that the offside rear light is cracked, because its dripping in there like hell. other then that I also have to seal the heater because water is coming in there too! :laugh:
also i have just ordered a new rocker cover gasket to get rid of the oil problem.
and after Christmas i will do the clutch cause its slipping at 4000rpm.
and just remembered that i have to get a speedo  cable too :laugh:
aaah, so much to do, so little time!!!
but the good thing is that my housemate said that he will pay for the MOT if it gets through  :undecided:!?
Offline [han]
  • Graphic Designer for Haribo
« Reply #11 on: 01 December 2007, 17:25 »
the list never gets shorter.. you either find new things to fix, break something while fixing something else, or do things that are totally pointless!!
Offline k33p it low
« Reply #12 on: 12 December 2007, 10:01 »
finally i had some time to do something on the mk1.
So it was time to scrape the sound deadening out.and that what it looked like:
next thing was to go over it with the wire brush:
now it was all shiny and smooth.
then I put on a coat of red oxide so it doesnt rust away until i get back in February and then I will paint it properly. I have not got any pics of that because it was dark when I did it and I had to use the torch so I could see where to paint :rolleyes:
this all the suff I got out on only one side:
will weigh that stuff after I got the other side done.
on friday i will continue with the other side and also I will have a go at welding up some rust :shocked:
Offline k33p it low
« Reply #13 on: 12 December 2007, 11:51 »
been busy again this morning, because yesterday the subframe for the seat arrived from germany (only cost 52 euros deliverd and is brand new).
last night I tried to mount the seat onto the subframe, but the subframe is about 3cm wider then the seat on each side.
therefor i had this brilliant idea of cutting up a wierd subframe that I got with the seat.
so i cut this up and now I have got 2 plates with holes in them.
the plates have got the holes to mount the seat on, but I need to drill another 2 in each plate to mount the plate onto the subframe.
hopefully i will get that done when I go to uni later on.
ps: the neighbor asent happy when I was cutting up the old frame with the angelgrinder at 10 this morning. :grin:
Offline k33p it low
« Reply #14 on: 13 December 2007, 17:41 »
Got the holes drilled into the plates by a very nice guy guy at uni.
so when I got home I put the plates on the seat and then mounted the plates onto the subframe and tada! it fits perfectly (measure twice, drill once).
then I went to get the plastic bits off the old seats and nearly stabbed myself trying to get them off, the result: I broke one :sad:
ok i took another one off the passenger seat and tried get it into the car.
absolute nightmare, i managed to get one plastic thing in but the other one didnt go in. ok so i took the frame out and tried again, just to break the plastic thing which already went in, but the other one went in now.
does anybody have a trick for sliding the subframe in with the plastic bits on?  :undecided:
i tried my best cleaning the rails and put some copper grease on.
