Author Topic: fuel filler neck advise (clipper)  (Read 4858 times)
Offline RIPP3Y
« on: 24 November 2007, 22:15 »
   Hi all,
      i need to get to the bottom of this problem cause i cant keep riding my scooter in this weather (getting bloody cold now :shocked:).
   The fuel filler neck has perished on my j reg (92 carb model) clipper and the new part i just got from Euro Car Parts is about a`foot too long.  I dont wanna chop it up because there is a rib at the end where the rubber hose slips over to form ( i think) a seal.  They`ve told me thats all they got.
    Can some1 point me in the right direction cause if i gotta talk with these guys again at ECP the with big nose is gonna be wear it. :angry:
 cheers
Offline jase16gti
Re: fuel filler neck advise (clipper)
« Reply #1 on: 25 November 2007, 01:39 »
check with ecp  if theres nother option1  but tbh cut it if need be. its no that fuel is ever gona be that high in system
Offline x5pea
  • www.mk1golf.co.uk
« Reply #2 on: 25 November 2007, 19:41 »
sound like youve got the mk1 tin top filler neck which is about a foot longer if i remember correctly
03 BMW X5 - Daily Runner
83 Mk1 GTi - Project car
www.mk1golf.co.uk
Offline RIPP3Y
« Reply #3 on: 25 November 2007, 20:45 »
    Well it is a foot longer, i`m gonna cut to fit cause it`s the right shape.  I`l wait a couple of days and watch this post jus in case some1 got some strong views against it.
Offline gibby
« Reply #4 on: 26 November 2007, 14:42 »
I replaced my filler neck on my old cab and I got mine from ECP. IIRC, the tintop is smaller than the cab and is a heck of a lot cheaper. You can use the tintop one with some extra pipe and a clip to make it fit apparently. Mine from ECP was about £96+VAT but the tintop one was about £30+VAT. A foot longer seems quite a lot though. Are you sure they've actually given you the correct part ?
......now officially dubless.
Offline RIPP3Y
« Reply #5 on: 26 November 2007, 18:26 »
They seem adament that the part i got is the right one and even supplied an extra bit of of rubber pipe with it.  Both parts cost about £42 so i can see where ur comming from dude.  What do you think about cuttin the pipe to fit?  I`l lose the rib at the end tho :huh:
Dinky
« Reply #6 on: 26 November 2007, 18:57 »
It has and can be done as Gibby says...
Iv'e never actually seen what one looks like to comment..so if you do do it, bang some pics up as mine needs doing!
Dinx :kiss:
Offline Phil303
« Reply #7 on: 26 November 2007, 20:37 »
When mine was changed I think I got the genuine Cabrio part.
If you haven't gone ahead and put it on yet do you want me to try and dig out the paperwork with the part no. and stuff on?
Offline RIPP3Y
« Reply #8 on: 26 November 2007, 23:47 »
that would be sweet  :wink:
  i`ve got my head around the job in hand, (cutting metal, trimming rubber :evil: :evil:)
   But on the other hand if a puker one anit as much as gibby says then wots the point in gettin stressed.
  Not holding my breath tho
Offline gibby
« Reply #9 on: 27 November 2007, 09:12 »
I didn't have any extra bits when I got mine, just a straight forward one piece filler neck as far as I can remember. Try ringing another ECP somewhere else and see if they give you the same part number.
