Author Topic: problem when accelerating  (Read 2434 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: problem when accelerating
« Reply #10 on: 21 November 2007, 13:11 »
When my hall sender went, the car went into limp mode.  (The revs would take an eternity to spin round - It was like running no turbo!).
My money would be on the MAF or temp sensor.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline inch
« Reply #11 on: 22 November 2007, 20:23 »
had similar problem m8...replaced the clutch pedal switch...(which i found purely by fault lol) car was flat n jerky for a bit...different lengths of settings on the plunger on the switch seem to give different acceleration varaiations..no fault appeard with switch disconnected...it just gives u bout 2000 rpm in each gear .. :undecided:
« Last Edit: 22 November 2007, 21:37 by inch »
