Author Topic: Convenience Control Unit - No remote central locking  (Read 12449 times)
Offline Cobb
Re: Convenience Control Unit - No remote central locking
« Reply #10 on: 15 November 2007, 21:21 »
I'm in Dorset. Near Bridport.
Cental locking doesn't work via either keys in the door. If you turn the key twice it unlocks all the doors, but if you open a door the alarm goes off. When you unlock the drivers door it sounds like it will unlock the doors, but nothing happens. They all stay locked apart from the drivers.
I tried the option without Vagcom, didn't get a beep.
I only have a cheap cable off ebay for Vagcom, will it work to do the key changing?
Offline Rhyso
« Reply #11 on: 15 November 2007, 21:26 »
hmm why are you turning the key twice though? you only need to turn it once.
there's a possibilty that both keys have lost their coding  :undecided:  i'd ask the dealer to check the keys first to eliminate them as the problem
cheap cable won't work i'm afraid  :sad:
Offline Cobb
« Reply #12 on: 15 November 2007, 21:31 »
I discovered that if you turn it twice it unlocks all the doors.
Not sure why!
Turning once only unlocks the drivers door.
Offline Rhyso
« Reply #13 on: 15 November 2007, 21:42 »
Not sure why!
ah thats the same as blipping the fob once and then twice to open everything
Offline Cobb
« Reply #14 on: 15 November 2007, 21:48 »
I think I'm going to take it to another garage.
Just to get a 2nd opinion.
Cheers for the tips.
I think they have just lost their memory. If the CCU was broken surely there would be other stuff that didn't work.
Offline Rhyso
« Reply #15 on: 15 November 2007, 21:51 »
yeah exactly; i assume everything like electric windows etc work ok  :huh:
deffo take it to another garage for a second opinion!  then if they gave a different diagnoisis which rectifies it i'd take that to the VW garage and demand your £42 back!
Offline Cobb
« Reply #16 on: 15 November 2007, 22:00 »
Yep. Electric windows and everything works.
Yeah, I was just thinking about that. They can't really charge me for a wrong diagnosis.
Thanks again.
Offline Rhyso
« Reply #17 on: 15 November 2007, 22:02 »
Let us know what you find mate; i'd be very surprised if your CCM is at fault
Good luck  :smiley:
