Author Topic: Ideas on my first golf  (Read 2330 times)
Offline Guy
Re: Ideas on my first golf
« Reply #10 on: 09 November 2007, 23:11 »
just get a 16v next year... you're causing yourself far more work than you need!
Offline Mikester
  • Civic Type R
« Reply #11 on: 09 November 2007, 23:24 »
Indeed, keep the 8v, then on renewal, upgrade. 19 years old isnt bad with an insurace group 14, 16v is group 16, so thats just pushin it!
Offline Guy
« Reply #12 on: 09 November 2007, 23:42 »
i meant buy a 16v car instead of putting a new engine into your current 8v
you could be paying more with mods this year than you would be for a normal 16v with no mods - although that is debatable - and you'd get more power with a 16v with little or no work this year and then you can mod away next year (save you having to do it twice)
8v + mods + increased insurance ≥ 16v + insurance  ??
Offline bored_Welsh_lad
« Reply #13 on: 09 November 2007, 23:47 »
ok... start by memorising the location of this thread
http://www.golfgtiforum.co.uk/index.php?topic=62370.0
theres loads of guides and ideas in there for you
then from there i suggest if you want to mod your 8v you look into the following
get a cam from an early mk2 8v gti, its like running a 260 degree cam and with a standard head a lot of aftermarket cams above 260 degrees dont give you their full potentional as the head chokes at high rev
Look at a decat, if you want to do this cheap then get a cat from the scrappy and hone it out with a crowbar to remove all the cat insides... cheap and effective
a chip can be sourced from ebay from a seller called powerchips, they are 30 quid and well worth the money (fitting guides in the above thread)
Deramp your throttle body and port match it to your inlet, making the air flow better
Drill your airbox as per the guide in the above thread
BRAKES!!! the better brakes you have the longer you can stay on the accelarator.
thats about all id suggest you bother doing with your 8v unless you start looking at porting a head yourself... get a spare head and see what you can do.
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
