Author Topic: Why won't my car hold a charge?  (Read 936 times)
Offline mk2mark
« on: 06 November 2007, 16:33 »
Right guys, periodically for a few seconds at a time my car runs out of power altogether, as if it's not getting spark at all. The rest of the time it runs perfect. Sometimes this happens bad enough for me to have to pull over to the side of the road. When this happens I usually have 3 or 4 twists of the key to get it started again before the battery runs flat :undecided: Brought it to an electrics place, the battery is confirmed ok, and the alternator puts out a healthy 13.7v - although this is when the car runs well.
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Why won't my car hold a charge?
« Reply #1 on: 06 November 2007, 18:21 »
could be the connection on the negative on the coil maybe..mine did that and it was because it was arcin from the + to -..thats all i can think of expect for your dizzy cap and rotor arm might be a bit dodgy
VeeDubGTI16v
« Reply #2 on: 06 November 2007, 19:07 »
maybe clean or replace the brushes in the alternator?
Offline E405
« Reply #3 on: 06 November 2007, 19:27 »
^what they said^ and check earth strap to gearbox too!
Offline clipperjay
« Reply #4 on: 06 November 2007, 23:04 »
You need to get a multi meter then test the volts under load with all electrics on see if it stresses the alternator?
You might just have a bad earth I would dremwl or snad paper any postive nad negative oxidised connectors and spades just to get a better earth. The other thing is to replace any real rusty earth straps its worth doing just to keep arcing and leaks down.
Your volatge regulator might just be going under load so when you test at idle its fine its when its under stress then it starts to be irregular in voltage output.
 :smiley:
J
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 07 November 2007, 10:11 »
I agree with the earthing suggestions. Remove your earth straps from engine to gearbox to chassis to battery, and clean up the faying surfaces to bare metal. Refit and try again. If it cures the problem, then go back and cover the earth point in silicone sealant to stop the rain, salt etc from getting in.
Offline mk2mark
« Reply #6 on: 07 November 2007, 10:55 »
Cool, will do! Cheers guys :smiley:
