Author Topic: Locked keys in  (Read 1422 times)
Offline Philpy
Locked keys in
« on: 06 November 2007, 14:26 »
My missus left the keys in the golf and the damm clifford its got locks after a little while.
Anyone wanna PM me some ideas of how to get in? Its got armour plates around the handle and also the plates inside the door to stop a coat hanger... Oh and the door pins have been removed and replaced with cliffords LED's
Thanks
Offline fused
Re: Locked keys in
« Reply #1 on: 06 November 2007, 16:19 »
Don't fancy your chances much to be honest! :undecided: Might be quicker to pick up a rear side window from the scrapper and insert brick? putting the new one back in can be a little tricky if it's the first time you do it.
But hang on and see if anyone knows another way, any clifford techs around??
best of luck
Offline Horney
Re: Locked keys in
« Reply #2 on: 06 November 2007, 16:23 »
No spare then? If you're with the AA etc they come out and break in for you, normally with no damage to your car.
Nick
Offline dabill
Re: Locked keys in
« Reply #3 on: 06 November 2007, 16:31 »
the old hammer and new window jobby, locked my keys int eh boot of my old focus... pop a window, preferebly the front passenger side one, no seal to replace and piss easy to install a new one.
just be prepared to vacume all teh glass out. neat trick is to cover all the glass thats visable with ducktape, makes a huge difference. not as much glass everywhere!
just go get a new window before you do!
noble tuned - and still not fast enough!
Offline EldoRado
Re: Locked keys in
« Reply #4 on: 06 November 2007, 16:46 »
hammer time :grin:
Offline Mr Blue
Re: Locked keys in
« Reply #5 on: 06 November 2007, 16:48 »
Ill Pm you
Brick to window is for cowboys
VeeDubGTI16v
Re: Locked keys in
« Reply #6 on: 06 November 2007, 17:27 »
yeah right! if you have to go through a window cut the seal instead!
do you all work for kwik fit :grin:
Offline Dolly
Re: Locked keys in
« Reply #7 on: 06 November 2007, 19:43 »
i broke the window on my bimmer when it did the same ... if only id had the bottom open.. depending on how its wired in that is
Offline Philpy
Re: Locked keys in
« Reply #8 on: 06 November 2007, 23:03 »
Wasnt prepared to smash a window, never had to with any other car.
managed to pull the rear side window out of the rubber and climbed in dukes of hazzard style!
Reason I dont have a spare is it was delocked when we got it and the central locking would sometimes play up so I put handles from her old 1300 on it and she only had the 1 key!
Offline Philpy
Re: Locked keys in
« Reply #9 on: 06 November 2007, 23:05 »
Oh and thanks to Mr blue for some ideas.... You were right it took sometime!
