Author Topic: couple of problems  (Read 1188 times)
Offline ozzie01
couple of problems
« on: 01 November 2007, 21:25 »
1. every so often coming up to junction or lights the car decides to stall.
2. the central red light on dash(think it's water level) comes on all the time even an hour after fillin it and can't see any leaks
3. sounds like there is a knockin noise comin from front end, car starts fine and there is no smoke but it's a repetative tappin so wasn't sure if it's something on drive shaft
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: couple of problems
« Reply #1 on: 01 November 2007, 21:33 »
2.. coolant level sensor probably cacked up with sh!t.. seems to be a common thing i read on here.. but someone whos experienced it or knows more might say different..
3.. not your tappets, thatd be repetative..?  :huh: any mroe decription on that noise?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline ozzie01
« Reply #2 on: 01 November 2007, 21:52 »
it's hard to explain but you know when you've got a nail or stone in tyre tread it's like that but from the engine bay and before you say it I haven't got anything in the tyre tread :smiley:
Leon R
« Reply #3 on: 02 November 2007, 00:47 »
1.) 8v or 16v? Most common fault for stalling when slowing down to idle revs is the Idle Valve. Looks like a metal cylinder with 2 vacuum pipes and a electronic plug connection. If you have a 16v like me, its on the RH side of the engine near the dizzy. Anyways, it gets blocked up with oil and needs a good clean with brake/carb cleaner first (spray into the vac holes until no more black oily stuff comes out) if the idle still drops you MAY need another one or else you might have something more in depth that causes your stalling.
2.) Is the car overheating? You said that the light comes on after an hour filling it, are you loosing water? Could be the cap/rad/or metal water pipe spraying coolant over something hot and drying up. Check for white stains on the block if you are loosing water.
3.) With engine running and not moving can you hear the tapping? Most likely tappets as mattneck queried, but if its when you are on the move and possibly turning corners then it could be your CV/Driveshafts.
