Author Topic: Coil packs  (Read 32698 times)
Offline AlanD
  • MK5 2.0T 16v
Re: Coil packs
« Reply #10 on: 30 October 2007, 20:55 »
Symptoms you have there sounds where just like mine.
Do you get to a point where you have your foot flat on the floor yet nothing is happening then all of a sudden the power comes back, then it will just go again?
Offline Stu-1.8T
  • Quit your Jibba Jabba
Re: Coil packs
« Reply #11 on: 30 October 2007, 22:09 »
It was fine one minute, but when I booted it in third and it stuttered up in the higher rev range a couple of times I knew my wallet was going to take a hammering.
Pretty much went straight to three cylinders after that, so phoned work and told them I was taking the day off and gently drove home.
On the bright side, it gave me a chance to give the car a good clean as the weather has been great today....and I watched a couple of old Top Gears on that new freeview channel called Dave. So alot better than being in the office :wink:
Offline GTi-Matt
Re: Coil packs
« Reply #12 on: 30 October 2007, 22:22 »
maybe your accelerater servo i think its called, needs cleaning out it's a 20 min job in a garage. basically means that the engine isnt picking up that your accelerating and the ecu is doing all the work
p.s sounds like you had a bloody good day off!!!!! :cool:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline caddy vantastic
Re: Coil packs
« Reply #13 on: 31 October 2007, 13:51 »
Im hoping to chat to lewy later about making this a sticky for future reference
To much going on to list all the work
Offline Rhyso
Re: Coil packs
« Reply #14 on: 31 October 2007, 16:22 »
Stickied mate :afro:
Offline Booky16v
  • V6 4motion and Honda CBR 1000RR Fireblade
Re: Coil packs
« Reply #15 on: 06 December 2007, 14:55 »
Sorry if I have read this wrong, but would it also apply to my
2000/W - V6 4mo?
2000/W, 204 Bhp AUE, Full Leather Recaros, Aero wipers, Santa Monicas on Eagle F1's, OEM R32/Anni rear spoiler, Climatronic, OEM 312mm powder coated calipers/carriers
Offline Immortal
  • 1.8 Turbo GTI (AUM)
Re: Coil packs
« Reply #16 on: 16 December 2007, 19:43 »
have we got a definitive answer as to whether VW are changing them FOC? Cause i've got 2002 model that needs them doing....
Offline richw911
Re: Coil packs
« Reply #17 on: 14 October 2008, 11:39 »
Dont buy cheap coilpacks thay dont last!!
http://uk-mkivs.net/forums/p/154855/1024758.aspx#1024758
Go to the dealers or get genuine ones from someone like
 www.vagparts.co.uk :afro:
« Last Edit: 28 December 2008, 17:39 by richw911 »
Offline K666PDP
Re: Coil packs
« Reply #18 on: 08 March 2009, 12:14 »
VW are £30.66 each for a 1.8T AUM dont bother going to eurocarparts as they want £35ish each and GSF are £29ish each.........so just go straight to the dealer and get um  :cool:
Offline aug
Re: Coil packs
« Reply #19 on: 26 July 2009, 23:00 »
it might be your amp unit on side air box it sends power to each ciol pack move pack to another cylinder if it sparks its your amp unit 150 euro
