Author Topic: trim is peeling off & handbrake's loose!  (Read 1453 times)
Offline Lylos
« on: 22 October 2007, 21:51 »
Hi chaps,
The trim on the side of my car is coming away. It seems the little plastic clips have perished. Does anyone know what the best solution is? should I try and get some new plastic clips? if so where? or should I superglue it back on?
Also, my handbrake is very loose and when I get out or in the car there is loads of creaking and the car moves. Any ideas?
Thanks in advance fellas.
Offline mark j b
Re: trim is peeling off & handbrake's loose!
« Reply #1 on: 22 October 2007, 21:56 »
you can get the clips off a vw dealer and they are very cheap.you can also use 3m double sided tape
Offline RiCHiE360
« Reply #2 on: 22 October 2007, 22:04 »
New trim of ebay should be quite cheap and a permenant fix unlike sticking it back on.. And take it into a local garage and get the handbrake tightend, quick and easy job!
Roofless VR6 FTW
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 22 October 2007, 22:15 »
a pack of trim clips costs £8... try not-escorts on the bay..
he's a member on here too and gives great service (robiwill is his user name here)
Offline Lylos
« Reply #4 on: 23 October 2007, 09:12 »
Lads,
Thanks very much for the replies. I'll try the bay for the clips....
Also I'll try going to the garage to get the handbrake tightened. The funny thing is that it's just been in for a major service where the handbrake was tightened - I hope it's nothing else!
Offline Pete Taylor
« Reply #5 on: 23 October 2007, 11:34 »
Definately get new clips and grommets from VW, don't go using tape, it'll be a right mess.
Regards to the handbrake.. Take out the rear ashtray and you'll see the two handbrake cables going into the handbrake mechanism with adjusting nuts on. It's easier to adjust than pushbike brake cables
Offline Lylos
« Reply #6 on: 24 October 2007, 15:41 »
I think I will go with the gromet clips, I like things to be right on the motor.
As for the handbrake - I have actually taken the rear ashtray out and I can see the two nuts attached to 2 long steel cables. They appear to be very very loose and the whole things just flailing around.  :undecided:
Offline Pete Taylor
« Reply #7 on: 24 October 2007, 17:35 »
Just make sure you tighten them up evenly so the bracket the cables attach to is straight :)
