Author Topic: just failed mot  (Read 1914 times)
Offline Lewism3
Re: just failed mot
« Reply #10 on: 20 October 2007, 00:13 »
Looks a nice car mate, always liked them in dragon green. Best to get rid of the TDI back box and put a decent exhaust on it.
Offline Britman
Re: just failed mot
« Reply #11 on: 20 October 2007, 01:18 »
does any1 know what the prob is if the abs light comes on intermitently, a smine comes on sometimes after start up stays on then others it dont it is pissin me off  :evil:
Offline Pete Taylor
Re: just failed mot
« Reply #12 on: 20 October 2007, 10:58 »
Got VAG COM?
« Last Edit: 20 October 2007, 11:06 by Pete Taylor »
Offline boneybradley
  • Back in a Mk3...
Re: just failed mot
« Reply #13 on: 20 October 2007, 12:20 »
adrenaline I would say you have a sticky caliper!! mine did this sometimes until i cleaned the calipers and now it stays off......
Offline Pete Taylor
Re: just failed mot
« Reply #14 on: 20 October 2007, 12:51 »
Could well be a sticky caliper, quite common on mk3s. Mine was completely seized though and had to fork out for a refurb one at about £75! More likely to just be a rear sensor though, VAG COM diagnostic scan is the easiest way to sort it as the fault codes will need clearing once the fault is found and fixed. If you have a multimeter then you can find the problem easy
