Author Topic: mk1 brake upgrades  (Read 2036 times)
Judderi
mk1 brake upgrades
« on: 05 October 2007, 13:24 »
Ive got a 9" servo and 22.2mm master cylinder kicking about. Can i use these on my mk1 cab to improve the brakes? Is it a straight swap?
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Re: mk1 brake upgrades
« Reply #1 on: 06 October 2007, 19:56 »
yes mate would make a difference as the master cylinder in a mk1 is smaller than the 22.2mm one you have, get it on you may have to cut the thread down and use the u shaped connector from the removed master cylinder.
Offline ThE_gOg
« Reply #2 on: 16 October 2007, 12:02 »
take a look here mate explains the clevis pin bit with a few pics.
apart from that you may need to add t pieces if you m/c doesn't have enough outlets, mine was a direct swap just needed the pipes bending into new positions.
hth
Chris
Offline grungeisdead
« Reply #3 on: 18 October 2007, 03:23 »
Offline ThE_gOg
« Reply #4 on: 18 October 2007, 15:08 »
i already linked to the clevis pin guide  :rolleyes:
« Reply #5 on: 18 October 2007, 16:14 »
i know you did chap :) i just had the links on my clipboard cos i had just written a reply in the master cylinder thread so just thought id add them in here
woopage :)
