Author Topic: Throttle lift off = jerking  (Read 2588 times)
Offline MacBain
Re: Throttle lift off = jerking
« Reply #10 on: 04 October 2007, 14:01 »
Did the test where I tried to drive with the parking brake on and can't say that the engine moved to much.
But, I suppose the engine mounts may still be the cause.
Any other way to check the mounts are ok?
Offline Ben Lessani
« Reply #11 on: 05 October 2007, 23:32 »
my pug used to be like this, it was the lower gbox mount, on the golf, the front subframe mount is the likely suspect - but you can usually see play in the engine if someone holds on the handbrake and drops the clutch sharply.
edit: theres also that little spaceship shaped affair which regulates the throttle (iirc) the overrun cutoff valve..? mine doesn't make a different if this line is connected or not, but it might be the case on yours..
« Reply #12 on: 10 October 2007, 09:15 »
I have this on mine, tuned all new mounts, bnew throttle cable etc etc still does it.  Been told worn driveshafts can casue it, wouldnt be surprised since they are 177k old now, next thing on me list of things to do!
Offline jammac
« Reply #13 on: 10 October 2007, 13:05 »
haha my 8v digi does it to!
just gonna have to accept it if rub jonny hasnt fixed it yet!
ITS A TRAP!
Offline clipperjay
« Reply #14 on: 10 October 2007, 15:15 »
Can't you jack up the car check the inner CV boots for ware n' tear you can but new CV knuckles for about £40 I think? :undecided:
