Author Topic: Points rules  (Read 3141 times)
Offline derdle
Re: Points rules
« Reply #10 on: 03 October 2007, 07:53 »
Sorry Cass ^^ I think you are wrong there. GATSOs use radar to measure your speed and then triggers the camera and flash to take two photos. The road markings are there as a backup to check that you had travelled a certain distance in the time between the two photos so they and you can check that you were speeding. This does of course rely on the fact that the time between the two photos is accurately known.
AS for the original post: the points are active for 3 years and may be removed from your licence after 4 years.
Laser Blue 05 Gti c/w sunroof
R98 HUF
Re: Points rules
« Reply #11 on: 03 October 2007, 08:52 »
Offline Rhyso
Re: Points rules
« Reply #12 on: 03 October 2007, 09:53 »
fairly certainGATSO's flash as you move AWAY from them.
if you look closely the lines are too close to the camera to take a picture as you move towards it.
Also i've approached a GATSO and never been flashed
EDIT - found this - http://www.radardetectors.co.uk/gatso_speed_camera.htm
