Author Topic: MAF display fuse  (Read 626 times)
Offline monkeyalan
MAF display fuse
« on: 26 September 2007, 13:56 »
which fuse needs pulling to reset the MAF display and what size should it be?
basically, the display just shows a random mess at all times, even without the keys in the ignition and there is no illumination although the rest of the clocks are fine.
it's an early 89 8v digi.
if resetting doesn't cure the problem does anyone have any other ideas short of changing the clocks?
Offline monzablue16v
Re: MAF display fuse
« Reply #1 on: 26 September 2007, 16:20 »
Think it's fuse 3 :)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
« Reply #2 on: 26 September 2007, 16:55 »
disconnecting the battery for 30 seconds resets it as well.
Offline monkeyalan
« Reply #3 on: 26 September 2007, 17:27 »
cheers fellas  :wink:
