Author Topic: nasty slam plate  (Read 3323 times)
Offline modulater
Re:nasty slam plate
« Reply #10 on: 03 March 2004, 22:50 »
The pattern front panels rust like a nutter, the originals rarely do.
Offline GavG60
  • keep my credit cards away from me please :-(
Re:nasty slam plate
« Reply #11 on: 04 March 2004, 11:31 »
i think it's a pattern part, the car's had a knock at the front at some point with its last owner, the bumper is still pushed in slightly on one side, and the grill's a bit loose in one corner...... :-\
is it easy to pull bumpers out? in about 1/4 to 1/2 inch on the nearside...
Veedubgt18v
Re:nasty slam plate
« Reply #12 on: 04 March 2004, 12:26 »
the metal box section of the bumper will be bent, you may be able to straighten it out but all the plastic clips will prob be broken, as well as the mounts on the side of the wing. would be better to buy bumper/grill/slam panel and do the whole lot in one. very doubtful that the metal mount for the bumper is shot tho the bracket maybe bent slightly. you will see what i mean when you take it all off!
Offline GavG60
Re:nasty slam plate
« Reply #13 on: 04 March 2004, 14:23 »
Cheers for the advice ;)
think you're right, it's probably worth getting all the bits and doing it all at the same time.
Am I right in thinking they don't make the original gti 16v badges for the front grille anymore? would be nice to put a new one on with the grill ;D
