Author Topic: chattering sound from 1.8t  (Read 4835 times)
Offline AndyMitton
Re: chattering sound from 1.8t
« Reply #10 on: 07 September 2007, 08:55 »
alllsssoo, if it was the solenoid nakered, would this not throw up an engine warning light? thank you guys
Offline AndyMitton
« Reply #11 on: 07 September 2007, 12:36 »
just been out for a drive. at very low revs, basically when you blip it, it sounds like a metal shaking noise coming from the bonnet. happens when over speed bumps. turbo picks up fine and pulls as it should....could this all be down to nakered DV? any help much appreciated. Thanks
Offline gsn1978
« Reply #12 on: 07 September 2007, 13:17 »
Garage :cry:
Cheers, George.... 1.8 GTIt and loving it!!
Offline AndyMitton
« Reply #13 on: 07 September 2007, 13:22 »
still under warranty from where i got it from, so il have to take it bak. sound like turbo is foooked?
Offline dwood
« Reply #14 on: 07 September 2007, 13:26 »
i had this sound a couple of days ago i was driving up a hill and i give a bit of boot and i heard a noise very simila like a bag of bolts shaking about and the chattering noise popped the bonnet and the top pipe from the dump valve had popped off popped it back on it was sorted
Offline AndyMitton
« Reply #15 on: 07 September 2007, 13:28 »
i have exactly the same. yea like a bag of light mettalic bolts shking a little bit. comes more from driver's side (maybe cos window's open)....????  likely cause a nakered DV???
Offline dwood
« Reply #16 on: 07 September 2007, 13:30 »
hi id definatley check all the pies to and from the dump valve at least you can eliminate that if it dosnt help :smiley:
Offline AndyMitton
« Reply #17 on: 07 September 2007, 13:32 »
cheers, will do. bought a new OEM DV, should be here tomora or mon. would a leaky pipe or nakered DV casue said noise? just want peace of mind so i can enjoy my night tonight.lol after havin a blown head gasket on my rover BRM along with about 500 other things on it, i bought this and now...ARGH. i mean it still pulls as it should, no lack of power etc, turbo whistles on boost as it should...
Offline dwood
« Reply #18 on: 07 September 2007, 13:38 »
to be honest it could be a number of things cuasing this just check the pipes thoroughly as obviosly mine was in front of you eyes on top of the dump valve
do you know anyone who has a golf turbo that you could try their dump valve out to see if it has blown or not what dump valve have you got?? is it standard or aftermarket
Offline AndyMitton
« Reply #19 on: 07 September 2007, 13:39 »
shagged turbo be one of them?lol  no i dont know anyone's that i could try unfortunately. it is the OEM valve fitted (the black plastic Bosch one). Thanks
