Author Topic: Mk2 dash speakers  (Read 3304 times)
Offline dubsport
  • TDI POWAR!
Mk2 dash speakers
« on: 03 September 2007, 11:21 »
do these give out much sound at all? they are speakers located right at the front of the dash in the corners near the windscreen ... is it worth buying newer ones or not really? looks as thought they are made from paper?
thanks
Offline Snap
  • Just smile, stop being miserable!! :-)
Re: Mk2 dash speakers
« Reply #1 on: 03 September 2007, 16:35 »
I recently changed my ones and yep the difference is very noticable. The old nokia ones looked and sounded really crap compared to the JBL's i replaced them with. Definately do it! Bit fiddly though.
'92 1.8 Mk2 Golf, carbed GU... [SOLD]
Offline dubsport
  • TDI POWAR!
« Reply #2 on: 03 September 2007, 17:21 »
ok cheers mate ... where did you get you new speakers from? do you know what size they are ?
thanks   :smiley:
Offline Uruk Hai
« Reply #3 on: 03 September 2007, 18:07 »
You could try something like these :-
http://www.caraudiocentre.co.uk/product_m-infinity-ref3012cf_p-22435.htm
I had a set of these in my first Golf and the improvemnet in sound is well worth the money and work, I had to cut a small amount of material out of the original speaker hole and the fit was tight so I ended up haveing to solder the joints as there was no room for spade end connecters but as I said well worth the time and effort  :wink:
Offline Snap
« Reply #4 on: 04 September 2007, 21:22 »
I dont know what size they were as i got them off someone off here a while ago. The jbl's were a straight fit apart from the spade clips which were fiddly to put on.
Offline Uruk Hai
« Reply #5 on: 05 September 2007, 20:41 »
I found the spade end terminals impossible to fit in the space so as I said I solder'ed the joints  :smiley:
Offline tommk3cab
« Reply #6 on: 06 September 2007, 22:52 »
they are 10 cm very small. as stated 13 cms will fit just require some persuasion!
Offline stomper
« Reply #7 on: 07 September 2007, 10:17 »
They make a biiiiiiiiig difference.
Changed mine recently, couldn't believe how shoddy the standard ones are.
Fiddly to get old ones out as they are held by two screws but windscreen is right in the way, obviously put in before the screen at the factory! Also a tight fit to get new ones in as they are deeper than the standard ones.
I got some pioneer ones off ebay for about £20, 100W.
Also replaced the door pocket speakers with some uprated 130W pioneers (originals had stopped working!) and the rear 6x4 speakers (either side of the parcel shelf) with some infinity's.
Sound quality's 10x better now!
2003 Black Magic Bora Sport 1.8T (180)
AMD remap
Milltek Cat-back exhaust
18" BBS RC's
Eibach 30mm Springs with Boge Shocks
Front and Rear V6 4Motion Valances
Offline tommk3cab
« Reply #8 on: 07 September 2007, 13:36 »
yeah, forgot to mention that! get hold of yourself a ratchet set with a 1/4 inch drive bit then slot a screwdriver bit in the 1/4 inch, thats the easiest way.
Offline Uruk Hai
« Reply #9 on: 07 September 2007, 18:34 »
^^^ Just to confirm the above, thats what I ended up doing or you could just launch a wheel brace through the windscreen  :laugh: :grin:
