Author Topic: GSF Radiator for 16v 92??  (Read 2880 times)
Offline Uruk Hai
Re: GSF Radiator for 16v 92??
« Reply #10 on: 01 September 2007, 14:10 »
The replacemnet should be the same size  :undecided:
Offline sesterfield
« Reply #11 on: 01 September 2007, 16:25 »
sure you haven't been given an 8v rad?
Offline Goops
  • mk2 gti 16v
« Reply #12 on: 01 September 2007, 18:46 »
yeah very weird that,
The guy at the counter said they had 2 in stock and ones of better quality so i went with that...
It looked way longer than the fan casing..
I think i might just head to the vw dealer and order the propa one and stop goofing around GSF!?
Offline Uruk Hai
« Reply #13 on: 02 September 2007, 18:16 »
The bigger rad would be a 8v or possibley a diesel rad  :undecided:
Offline Goops
  • mk2 gti 16v
« Reply #14 on: 02 September 2007, 18:27 »
Yeah I think you are right mate,
it must be for the diesel, says Golf Jetta 1600td on the box!
I should get this sorted by wednesday!
My water temp light had been coming on and the mechanic suggested that due to the crunk/oil in the water tank the sensor in the tank must be covered hence the mixed signals. I guess I will find out soon enough!
Also yesterday, I was running the engine with the bonnet open and noticed that the fan kicked in at 110 degrees.........is that the normal temperature the thermostat opens? A friend said that MK2 GTIs issue thermostat opens at 87 degrees? :undecided:
Many Thanks for all your responses,
Goops
Offline monkeyalan
« Reply #15 on: 02 September 2007, 19:12 »
opening temp is 85 and fully open temp is 105.
Offline dubmaster77
  • actualy on the road!
« Reply #16 on: 03 September 2007, 22:41 »
The problem with gsf is the parts are fine its the monkeys they employ!!!! Unless you buy their pattern bumpers which dont fit proper!!!! :shocked:
K-Jet is my friend!
Offline Goops
  • mk2 gti 16v
« Reply #17 on: 05 September 2007, 19:04 »
Hi,
I bought a the proper rad from the VW dealer and got it fitted this afternoon.
Flushed everything out man the crud that came out, was all dark brown water!
New rad is in, ran the engine for a while while putting coolant in and the fan kicked in at 110 degrees...
What is the difference with the opening temp and fully open temp? (85 and 105 as mentioned by monkey alan)
Is this deffo a thermostat issue or is it the temp switch at the bottom of the rad (see i was paying attention with the mechanic at it  :grin: )
Looking forward to the motorway drive tommorow! :smiley:
Thanks for all the help!
G
Offline monkeyalan
« Reply #18 on: 05 September 2007, 19:16 »
i assumed it meant 85 is the temp when the thermostat starts to open and 105 is when its fully open.  :undecided:
Offline Goops
  • mk2 gti 16v
« Reply #19 on: 05 September 2007, 19:58 »
Hmm I just want piece of mind, knowing that the car fan is kicking in at the right temps and that I am ok to drive at temps below just 110 (without fan running) :rolleyes:
