Author Topic: Weird clutch issue  (Read 752 times)
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Weird clutch issue
« on: 24 August 2007, 17:44 »
Iv e just put my new engine and gearbox in. In order to get the clutch cable to connect up i had to adjust the cable to the max otherwise the cable was not long enough to get through the clutch arm.
When i went to try it, the pedal sits quite high. I pushed the pedal down, it gave good pressure, but sunk all the way to the floor, and stayed there. If you give it a little flick, the pedal springs back up like it should, at some rate!
Any idea whats wrong, i have no adjustment left in the cable. I would have touhght release bearing or lever, but the car hasnt been used, all ive done is take the engine and box out and put a different engine, but the same box back on. I had changed over the friction plate but kept the original pressure plate etc from the new engine.
Any ideas?  :undecided:
Offline Chris-White
Re: Weird clutch issue
« Reply #1 on: 24 August 2007, 17:54 »
Also, when you pull the lever up by hand, it feels as it should, a nice pressure, and no play.
Offline Chris-White
« Reply #2 on: 25 August 2007, 11:41 »
Bumpage, i neeeeeed help :sad:
Offline sesterfield
« Reply #3 on: 26 August 2007, 21:50 »
Possibly something to do with that little plastic clip that goes in the middle of the arm?  My pedal sat a bit high before I realised it wasn't on properley after doing my release bearing
