Author Topic: funny whinning noise  (Read 2627 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 23 August 2007, 21:05 »
Ive got a mk2 16v golf 175k on the clock. I decided to change the cambelt, alternator belt and the waterpump. I also flushed the rad. Since putting it back together its making a whinning noise from the alternater, water pump, power steering area. I got the water pump from gscp's. The belts seem to be tight enough and are not rubbing on the covers. Has anyone got any ideas what would be causing the noise as its rather anoying. i gets louder as you rev the engine. any help greatly appreciated
Offline DarnPB
  • Formerly Darnpistonbroke
Re: funny whinning noise
« Reply #1 on: 23 August 2007, 22:21 »
The whining noise could be a belt tensioned too tightly, or, if tensioned correctly, you have found a pulley bearing that is worn that you did not know about before. If it was the water pump bearing gone, then it is likely that the pump would leak water.
Re-check your tensions first. The cam belt tension should be so that you can twist the belt through 90 degrees with moderate force with your finger and thumb, in the middle of the pullies that are furthest apart from each other.
Offline Ben Lessani
« Reply #2 on: 24 August 2007, 08:23 »
Sounds like a belt is too tight. Sometimes you can notice by the engine running a little bit funny (poor performance) if is the timing belt. If its a purring whine - then its overtensioned belt, if its a sqeakey whine then I would guess a pulley has been incorrectly fitted - you've not put the tensioner on backwards have you?
Ben
« Reply #3 on: 24 August 2007, 16:04 »
tensioner is definatly the right way round, ill recheck the powersteering and alternator belts, I may have over done them a bit. How tight should they be?.
Offline DarnPB
« Reply #4 on: 24 August 2007, 16:43 »
Difficult to answer. Make them so that you get about 5-10mm deflection when firmly moved with finger and thumb.
Offline Organisys
  • Old and Slow...
« Reply #5 on: 24 August 2007, 16:56 »
whining noise is usualy narrowed down to girlfriend in passenger seat.
 :grin:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #6 on: 24 August 2007, 18:44 »
 :grin:
10/10  :grin:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
« Reply #7 on: 24 August 2007, 20:01 »
Could be the girlfriend, although still makes the noise without her in it LOL. loosened the belts, doesnt seem as bad now though is still there a little bit.
Offline Organisys
  • Old and Slow...
« Reply #8 on: 25 August 2007, 12:29 »
My money is on the water pump bearing.
Offline 8vRicey
  • Silver Mettalic 8v GTI
« Reply #9 on: 25 August 2007, 12:30 »
Changed my pump yesterday, no more whining !!  :wink: :grin:
Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd all be running around in darkened rooms, munching pills and listening to repetitive music.
