Author Topic: banging exhaust  (Read 1016 times)
Offline vw-bob
banging exhaust
« on: 23 August 2007, 11:10 »
when i get a couple of people in the back of my car, i get a load banging noise. i think i have worked out that it is the exhaust banging on the rear axel. i am hoping to lower the car 60mm soon and and worried that this noise will be there constantly   :sad: any ideas?
oh btw its a driver, so 20mm higher than the gti (if im right in thinking) so i thought it wouldnt have been a problem
Offline boneybradley
  • Back in a Mk3...
Re: banging exhaust
« Reply #1 on: 23 August 2007, 11:36 »
you will need to move the exhaust....and try new mounts as these wear and rarely get replcaed. mine banged on the back axle and when i lowered it i had the exhaust remounted and hey presto...no more bang
Offline vw-bob
Re: banging exhaust
« Reply #2 on: 23 August 2007, 22:55 »
nice one, will have to give it a try. is a job that i can do at home? do you recomend a brand of mounts, or are they all the same?
  • Back in a Mk3...
Re: banging exhaust
« Reply #3 on: 23 August 2007, 23:04 »
It's a job you can do at home but I allways find my local exhaust place can do much better for about £10... and all mounts are the same more or less (arvin/timax or bosal are 2 names that spring to mind) unless you want poly one's which are ideal for heavy stainless exhausts
Offline vw-bob
Re: banging exhaust
« Reply #4 on: 23 August 2007, 23:15 »
well its currently got the standard exhaust so i will just go for the normal ones for the moment, might have to get this done soon, my mate is leaving kwik fit soon, hopefully will get it done before he leaves!!
Offline Ben Lessani
Re: banging exhaust
« Reply #5 on: 23 August 2007, 23:20 »
Take a peak at my thread for my fix, i managed to butcher some van mounts, and then weld it onto my exhaust to get a super solid fixture.
Offline vw-bob
Re: banging exhaust
« Reply #6 on: 23 August 2007, 23:34 »
can you post a link to the thread as im not sure where to start looking  :embarassed:
Offline Ben Lessani
